#1 2012-08-21 16:32:41
TankerTom
Problem with the Autopano Giga
after a long time I am once again gotten to photograph a panorama, and thus try out the new software. I've gained Kolor Autopano Giga.
The panorama itself was created with a EpicPro. There are 1560 images emerged.
The Import Wizard is the software showed all the images in the correct order. The settings in Autopano were left. Then "Run" release the software and you see the result after 8 in the appendix. Why is it that when something like this comes out. Doing something wrong in the settings of the software?
Sorry for my bad english.
TT
Uploaded Images
#2 2012-08-22 13:11:53
Website
Re: Problem with the Autopano Giga
TankerTom wrote:
TT
Could you show your import settings for this pano? Use "skip optimizing", check "use hard links".
This might help: http://www.autopano.net/wiki-en/action/ … zard_Cases (it´s PApyWizard - but the point is the unlinkin/hardlinking/optimizing strategy)
#3 2012-08-22 17:33:58
Website
TankerTom wrote:
TT
Does the pano really have a 360 HFOV?
The Gigapan robots are not really ideal for shooting panos with a 360 degree HFOV because they can only shoot a regular grid/matrix of images.
If your pano really does  have a 360 degree HFOV did you check the appropriate box in Shoot setup settings:
Uploaded Images
#4 2012-08-23 15:42:58
TankerTom
without the Import Wizard it worked out, but the panorama missing 247 images. How to add the?
TT
