#1 2012-08-02 18:31:47
infinityspiral
Lock Pan tool movement to X or Y axis while holding SHIFT
In Photoshop/Illustrator/etc it's common to move an image along only the X or Y axis if SHIFT is being held down.  When I edit a Panorama, a frequent adjustment I make is just to pan the image left or right  to adjust the composition.  Without being able to lock the axis though I usually end up with an wavy panorama that takes additionally nudges to get everything back into a straight line again.  It's be much faster to grab one side, hold down SHIFT then drag left or right so that the wave effect doesn't occur.
#2 2012-08-02 19:46:23
Website
Re: Lock Pan tool movement to X or Y axis while holding SHIFT
Try setting the grid to display in the Editor and then use the centre point tool to pan the image along the horizon line.
#3 2012-08-03 13:48:11
Kolor CEO
Website
Is is available in autopano v3 alpha 1 ( not really well done in fact, it has been improved for alpha 2 ).
