#1 2012-07-28 11:22:09
sdesnault
Camera and lens profiles / optimum settings
I have the feeling (maybe misguided?) that serious panorama photographers are using a small number of body/lens configurations. I know that on the Nikon side, the Sigma 10-20, Nikkor 10.5 Fisheye, 10-24, 12-24 are widely used on DX bodies, while the 16mm FE and 14-24 are used on FX - I'm probably missing some combinations at less wide angles, but you get the picture.. it's a fairly reduced number of lenses.
Could't APP directly pick up the lenses from the image info and set up the more sophisticated parameters of lens correction automatically?
Or is there a place in the forums with a table for optimal parameters?
It's almost impossible to find the best ones via trial and errors, given the many options available.
Thanks in advance and best regards.
Stephane
#2 2012-11-20 12:06:45
M.Estevez
Re: Camera and lens profiles / optimum settings
Hi Iam new in the Forum
I use a 8 mm in a 7D canon (1,6)
takes four images around,1 zenit and 3 for nadir,2 with tripod and one without
Regards
#3 2012-11-20 13:05:26
Website
Given you use an original lens matching the body: it does. It´s in the EXIFs. What do you mean: "more sophisticated informations"?
As well as Photoshop as an example can read "sophisticated informations" from the lens regarding geometrics for dealing with abberations and so on
APP/APG reads this informations also afaik from the EXIFs.
I guess it uses these informations for the lens-correction algos.
I have no information about how APP/G handles non-original lenses resp. lenses which don´t provide any EXIFs in terms of lens-corrections.
There´s an automatic feature . . but what it does exactly i don´t know - but somehow it works fine . . winkcool
My experiences after about 6 years of use: APP/G does very, very well. My suggestion: don´t try to save money on lenses - use the best you can afford
and better buy ONE real good lens than several mediocre ones.
#4 2012-12-19 13:00:52
cherylkerns
Website
Nope, Picking up the lenses directly from the image info and set up the more sophisticated parameters of lens correction automatically is very difficult.
I have no information about it.
Yeah, It's impossible for me too
Repo boats for sale - Now You Can Shop Where the Dealers Find Their Deals
