#1 2012-07-21 19:13:22
Igorvirtual
Pleas help !
Please help. Created virtual tours, Cover, and beauty center - Beauty Shop, Shop. On the cover you can go to any of the three rounds.http://www.pskovsalon.ru/tur/NEW/build.html  When any of the tour click on the top left corner of the logo, the new window opens, but it should open a window cover. Many windows appear. How to make the transition from any of the tour on the cover of the new window is not opened, and the old? Take a virtual tour created in Panotour 1.6. Thank you all!
#2 2012-07-21 20:00:01
Website
Re: Pleas help !
I think the first screenshot displays the options you seek?
It may be that this was not available in 1.6, in any case I recommend that you upgrade to 1.8.
Unfortunately the same dropdown list of options is not offered for logo links, but you can enter the appropriate values yourself - as shown in screenshot 2.
Uploaded Images
#3 2012-07-21 21:22:42
Igorvirtual
Re: Pleas help !
Thank you Andrew !!! Write like this: http://www.pskovsalon.ru/tur/NEW/build.html, _self
Yes ? So send a link to LOGO in the upper left corner of every virtual tour?
#4 2012-07-21 21:35:20
Website
Re: Pleas help !
Yes, that should do what you want I think.
Let me know if it works.
#5 2012-07-22 08:33:31
Igorvirtual
Re: Pleas help !
Did as you said, while maintaining says "Error" and the label appears on the screen. Of course this is not for this reason that I wrote _self, but I did not save the project. What is the cause of the error?
Uploaded Images
#6 2012-07-22 09:20:52
Igorvirtual
Re: Pleas help !
Andrew everything turned out. The mistake was, the program could not find some. Swf-files, I again set the path to it. All did as you said and it worked. Look, now many windows will not open http://360virtualexpress.ru/NEW/build.html  Thank you so much! You really helped me!
