#1 2012-06-09 00:06:02
danny
XML generation problem
Hi. I have  a problem with panotour xml code generation!.
I have tryed checking and unchecking the boxes to generate the xml file but it does not appears. What could be the problem/solution ?
#2 2012-06-09 01:20:45
Website
Re: XML generation problem
Hi.... Very strange... You might want to un-install and try again, or it might be that you have your xml files set to invisible files... or you are using a trial version of ptp... The trial version has xml file restrictions..
#3 2012-06-09 06:49:31
Website
Welcome to the forum...
Are you using a Demo version of Panotour Pro?
If so XML output is not available in the Demo version.
