| User list | Rules | You are not logged in.
win7 , netbook acerone, last papywizard
the hed move well but shutter fail this is the log any help?
ty
Fiore
2012-03-17 11:55:52,421::Main::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2012-03-17 11:55:52,421::Main::INFO::Starting connection. Please wait...
2012-03-17 11:55:52,483::Main::DEBUG::PluginsConnector.start(): 'yawAxis' establish connection
2012-03-17 11:55:52,483::Main::DEBUG::BluetoothDriver._init(): trying to connect to 00:12:6F:22:3F:50...
2012-03-17 11:56:02,904::Main::DEBUG::BluetoothDriver._init(): successfully connected to 00:12:6F:22:3F:50
2012-03-17 11:56:02,904::Main::DEBUG::PluginsConnector.start(): 'yawAxis' init
2012-03-17 11:56:03,108::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2012-03-17 11:56:03,170::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-03-17 11:56:03,186::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-03-17 11:56:03,200::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' establish connection
2012-03-17 11:56:03,200::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' init
2012-03-17 11:56:03,295::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2012-03-17 11:56:03,342::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-03-17 11:56:03,404::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-03-17 11:56:03,404::Main::DEBUG::PluginsConnector.start(): 'shutter' establish connection
2012-03-17 11:56:03,404::Main::DEBUG::PluginsConnector.start(): 'shutter' init
2012-03-17 11:56:03,513::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2012-03-17 11:56:03,559::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-03-17 11:56:03,621::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-03-17 11:56:03,621::Main::INFO::Connection started
2012-03-17 11:56:03,825::Spy::INFO::Spy resumed
2012-03-17 11:56:07,724::Main::DEBUG::NbPictsController._onAccepted(): nb picts set to yaw=2, pitch=1
2012-03-17 11:56:11,359::Main::INFO::Show shooting counter
2012-03-17 11:56:15,134::Shooting::INFO::Start shooting process...
2012-03-17 11:56:15,151::Shooting::DEBUG::Shooting.start(): create mosaic data object
2012-03-17 11:56:15,151::Shooting::DEBUG::Data.__init__(): create xml tree
2012-03-17 11:56:15,165::Shooting::DEBUG::Data.createHeader(): values={'comment': u'Generato da Papywizard 2.1.21', 'cameraOrientation': u'portrait', 'yawNbPicts': '2', 'timeValue': '2.0', 'pitchNbPicts': '1', 'title': u'Ecco il titolo', 'bracketingNbPicts': '1', 'counter': '001', 'stabilizationDelay': '2.0', 'overlap': '0.25', 'headOrientation': 'up', 'lensType': u'rectilinear', 'yawRealOverlap': '0.25', 'pitchRealOverlap': '1.00', 'sensorCoef': '1.6', 'sensorRatio': u'3:2', 'roll': '90.0', 'focal': '18.0', 'gps': u'Ecco la posizione'}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=header, tag=general, value=None, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=general, tag=title, value=Ecco il titolo, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=general, tag=gps, value=Ecco la posizione, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=general, tag=comment, value=Generato da Papywizard 2.1.21, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=header, tag=shooting, value=None, attr={'mode': 'mosaic'}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=headOrientation, value=up, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=cameraOrientation, value=portrait, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=stabilizationDelay, value=2.0, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=counter, value=001, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=startTime, value=2012-03-17_11h56m15s, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=endTime, value=2012-03-17_11h56m15s, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=header, tag=camera, value=None, attr={}
2012-03-17 11:56:15,165::Shooting::DEBUG::Data._addNode(): parent=camera, tag=timeValue, value=2.0, attr={}
2012-03-17 11:56:15,181::Shooting::DEBUG::Data._addNode(): parent=camera, tag=bracketing, value=None, attr={'nbPicts': '1'}
2012-03-17 11:56:15,181::Shooting::DEBUG::Data._addNode(): parent=camera, tag=sensor, value=None, attr={'ratio': u'3:2', 'coef': '1.6'}
2012-03-17 11:56:15,181::Shooting::DEBUG::Data._addNode(): parent=header, tag=lens, value=None, attr={'type': u'rectilinear'}
2012-03-17 11:56:15,181::Shooting::DEBUG::Data._addNode(): parent=lens, tag=focal, value=18.0, attr={}
2012-03-17 11:56:15,181::Shooting::DEBUG::Data._addNode(): parent=header, tag=mosaic, value=None, attr={}
2012-03-17 11:56:15,181::Shooting::DEBUG::Data._addNode(): parent=mosaic, tag=nbPicts, value=None, attr={'yaw': '2', 'pitch': '1'}
2012-03-17 11:56:15,181::Shooting::DEBUG::Data._addNode(): parent=mosaic, tag=overlap, value=None, attr={'yaw': '0.25', 'minimum': '0.25', 'pitch': '1.00'}
2012-03-17 11:56:15,384::Shooting::DEBUG::Configuration saved
2012-03-17 11:56:15,384::Shooting::DEBUG::Shooting.start(): repeat 1/1
2012-03-17 11:56:15,384::Shooting::DEBUG::Shooting.start(): pict #1 of 2, index=(1, 1, 1), yaw=-17.0, pitch=0.0
2012-03-17 11:56:15,384::Main::DEBUG::ShootController.__onShootingUpdate(): index=(1, 1, 1), yaw=-17.0, pitch=0.0, state=None, next=True
2012-03-17 11:56:15,415::Shooting::INFO::Moving
2012-03-17 11:56:15,431::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2012-03-17 11:56:15,431::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -17.0
2012-03-17 11:56:15,463::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to 0.0
2012-03-17 11:56:34,244::Shooting::INFO::Stabilization
2012-03-17 11:56:34,244::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2012-03-17 11:56:36,257::Shooting::INFO::Shutter cycle
2012-03-17 11:56:36,257::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2012-03-17 11:56:36,257::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2012-03-17 11:56:38,426::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-17.0, pitch=0.0, roll=90.0
2012-03-17 11:56:38,426::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '1'}
2012-03-17 11:56:38,426::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2012-03-17_11h56m38s, attr={}
2012-03-17 11:56:38,426::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-17.0', 'roll': '90.0', 'pitch': '0.0'}
2012-03-17 11:56:38,551::Main::DEBUG::ShootController.__onShootingUpdate(): index=(1, 1, 1), yaw=-17.0, pitch=0.0, state=ok, next=None
2012-03-17 11:56:38,582::Shooting::DEBUG::Shooting.start(): position index=(2, 2, 1), yaw=17.0, pitch=0.0
2012-03-17 11:56:38,582::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=17.0, pitch=0.0, state=None, next=True
2012-03-17 11:56:38,612::Shooting::DEBUG::Shooting.start(): pict #2 of 2, index=(2, 2, 1), yaw=17.0, pitch=0.0
2012-03-17 11:56:38,612::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=17.0, pitch=0.0, state=None, next=True
2012-03-17 11:56:38,628::Shooting::INFO::Moving
2012-03-17 11:56:38,628::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2012-03-17 11:56:38,644::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 17.0
2012-03-17 11:56:38,690::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to 0.0
2012-03-17 11:56:53,510::Shooting::INFO::Stabilization
2012-03-17 11:56:53,510::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2012-03-17 11:56:55,523::Shooting::INFO::Shutter cycle
2012-03-17 11:56:55,523::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2012-03-17 11:56:55,523::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2012-03-17 11:56:57,644::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=17.0, pitch=0.0, roll=90.0
2012-03-17 11:56:57,644::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '2'}
2012-03-17 11:56:57,644::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2012-03-17_11h56m57s, attr={}
2012-03-17 11:56:57,644::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '17.0', 'roll': '90.0', 'pitch': '0.0'}
2012-03-17 11:56:57,786::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=17.0, pitch=0.0, state=ok, next=None
2012-03-17 11:56:57,816::Main::DEBUG::ShootController.__onShootingUpdate(): index=(3, 2, 1), yaw=17.0, pitch=0.0, state=None, next=True
2012-03-17 11:56:57,848::Shooting::INFO::Shoot process finished
2012-03-17 11:56:57,848::Main::DEBUG::ShootController.__onShootingStopped(): status=okOffline
the head move well but shutter fail this is the log any help?
ty
Fiore
Are you using a wired or wireless (Bluetooth) connection between Papywizard host platform and the Merlin mount?
What camera are you using?
Has the shutter trigger via Papywizard ever worked correctly?
Yes I use the bluetooth panoger.
I'm using different camera Nikon D300S , Canon EOS 5D Mark II and tha cables work well both.
No the shutter trigger never worked , Tjis is my first time I try.
Ty
Fiore
Ty
Fiore
You say "the cables work well both" and also "the shutter trigger never worked".
These statements seem to contradict each other?
What values have you set for the shutter plugin?:
Sorry for my bad english. I will try to explain : The shut don't work from papywizard but If I try to shut with the same cable and a remote control the shut work so the cables are not damaged . Thesetting si like on your pictures I have tried to increase the Time value because in other post a guy solved to up to 1,5 .
Pulse width high and low are to 250ms too
Ty
Fiore
OK.
The setting is like on your pictures I have tried to increase the Time value because in other post a guy solved to up to 1,5 .
Time value should be set to provide sufficient time to complete the exposure(s), before head starts moving to the next shooting position.
Ty
Fiore
Try increasing Pulse width high value.
Other than that you could test whether the circuit is closing using a multimeter. It is possible there is a fault with the internal wiring to the Snap connector socket in the Merlin mount.
Hello Fiore,
If the change of the pulse lenght don't solve the problem ...
Then, you should check the contacts on the level of the mainboard
and to invert the polarity at the opto-coupler connector ...
All details concerning specific camera remote wirings:
http://www.doc-diy.net/photo/remote_pinout/
Ty very much for the replies to all.
Now the Orion works , I will test outdoor in the next days.
Fiore
Now the Orion works ...
Fiore
What was the problem?
COMMUNITY Forums YouTube channel Google+ |
COMPANY Blog About Kolor Resellers Contact Visit us |
