#1 2012-03-13 19:24:34
vik
Custom, memory efficient script for KRO => DZI
Hi;
I was not satisfied with gigatiler;
So I made my own tool for splitting a .kro file to a dzi (deep zoom image) format, so it can be viewable in seadragon
I made it memory efficient (ex: 100mo usage for a 4.6go image)
You can get a 10 times smaller output than with gigatiler (in jpg format)
you can get it here : https://github.com/vikbez/kro2dzi
you need to install python and pil to use it
(edit the script for options if needed)
simply drag n drop the .kro file on the script, output will be generated in the same folder than the .kro file
tested on win 7 64 with python 2.7 and pil library 64
remarks welcome
#2 2012-03-14 08:39:20
Kolor CEO
Website
Re: Custom, memory efficient script for KRO => DZI
Good ! This is nice.
#3 2012-03-15 16:30:06
vik
... and made a version for standard image files
here : https://github.com/vikbez/img2dzi
