| User list | Rules | You are not logged in.
Panotour pro 1.7.3 64bit on Mac
I had a three scene tour. The first scene had a sound hotspot, with a rotational effect. I deleted this using panotour interface, but the sound wouldn't disappear. I rebuilt the tour in a new directory and the sound still didn't disappear.
In the end I edited the .kpt file to remove the sound hotspot, and then the sound finally went away. ![]()
regards
Gareth
Bug reproduced on our side.
I opened the issue N°1197 on this problem.
Meanwhile, the only way to remove sound spots is the way you did :
- Edit the project kpt file with a text editor
- Find the "Spot" nodes with "SoundSpot" attribute set to true
- Find the one you want to deleteamong those sound spot
- Delete the 4 lines describing this spot, beginning with <Spot> and ending with </Spot>
COMMUNITY Forums YouTube channel Google+ |
COMPANY Blog About Kolor Resellers Contact Visit us |
