#1 2012-02-04 22:16:05
Remko
APG 2.6.1 - issue with Neutralhazer
I am working with the trial version of APG V2.6.1 on a Mac with 10.7.2 running.
I try to get the Neutralhazer working but somehow it doesn't. I watched the video with Arnaud Frich about this subject and am repeating his steps. Might be that I am doing something wrong, but cannot figure out what it might be.
I have 5 photos imported. I click on the Plugin Wizard and select the Neutralhazer. So far so good. In the Neutralhazer window APG selects the 3rd photo, I adjust the slider to my liking and then click on "apply to all images". I then click "Finish".
As a result *only* the first 3 images appear with the name of the photo (and _dehazed added to their name). Why do I only get 3 images and not all five?
I played around, by first selecting all images and then selecting the Plugin Wizard, but to no avail. Next time, being in the Neutralhazer window, I selected every images one for one. Still no good.
Any help / suggestions are highly appreciated.
BTW: I do like the effect of the Neutralhazer on the images, very impressive! Now if only I got the plugin to work on all photos .... wink
cheers,
Remko
#2 2012-02-04 22:22:34
Website
Re: APG 2.6.1 - issue with Neutralhazer
cheers,
Remko
Hi!
Take care to have selcted ALL images.
best, KLaus
„It’s not creative unless it sells.″ Leo Burnett
#3 2012-02-04 23:17:14
Remko
Hi Klaus,
Thanks for stepping in.
As far as I know I did selected all images, as I described above. What I did was clicking on every image with the shift key pressed. The surroundings of all images turned gray. I then choose the Pluginwizard.
Is there another way to have all images selected?
cheers,
Remko
#4 2012-02-05 01:04:45
Website
#5 2012-02-05 12:12:54
Remko
Hi Georg,
No I haven't, so I took a look at the reported fixes straight away. For both RC1 and RC2 my issue is not listed , so it is my guess that using the beta does not solve my problem.
But thanks anyway!
Cheers,
Remko
#6 2012-02-08 17:57:34
Absolute beginner
Website
The trial version of Autopano Giga does limit the use of plugins like Neutralhazer to the 3 first images only.
#7 2012-02-08 19:50:52
Website
Ooops! cool
#8 2012-02-08 21:40:44
Remko
Aha, thank you so much, AlexandreJ, that explains it!!
cheers,
Remko
#9 2012-02-10 18:44:31
Remko
Update: just to let you know I bought a license key yesterday for APG and now the Neutralhazer works perfectly wink
cheers,
Remko
