#1 2012-02-03 15:57:41
Kolor CEO
Website
Autopano Engine 2.6.2 RC 2
Just another RC release with some nice fixes as well as improvements in GPU support :
Revamped 360° blending
With engine 2.6.1, we introduced a new generic 360° blender that had some issues with soft rendering and uses more memory. We improved all parts : sharp rendering, less memory used but still with better blending over 360° edges compared to 2.6.0 engine.
New compatibility mode in GPU support
We introduced a compatibility mode in GPU support so that even fairly old GPU can use this mode in Autopano Pro. The GPU check has also beeing improved to check for both mode.
Fixes :
- 0000602: [Unclassified] Crash when using PtGui import - resolved.
- 0001147: [Cortex ( rendu )] HDR output issue (grey in burned zone) - resolved.
- 0001142: [Cortex ( rendu )] Softness issue in rendering (360° case) - resolved.
- 0001140: [Cortex ( rendu )] Not enough memory for rendering one line (360° case) - resolved.
- 0001148: [Cortex ( rendu )] Force Mercator and auto-crop conflit - resolved.
- 0000998: [Editor] MAC : some issue with a given GPU - resolved.
- 0001072: [UI behavior] Add GPU compatibilty mode in global settings - resolved.
- 0001125: [Editor] GPU compatibility mode - resolved.
- 0001133: [Image I/O] Image blurred when using haze on small size image - resolved.
- 0001138: [Cortex ( rendu )] Blending on zenith - closed.
Download
http://www.kolor.com/download-autopano- … .html#beta
Take care,
Alexandre
