#1 2012-01-27 11:57:53
Absolute beginner
Website
Autopano Engine 2.6.2 RC 1
Another small release candidate to introduce a crash analysis system.
With this version, we'll be able to find the real reason of the seldom windows 7, 64 bits folder browser crash.
Main changes
Papywizard focal length integration
Sometimes, it is really needed to check that focal length provided by images and provided by XML are good and matching. In some case, you just don't have any focal length. We added an easy way to do that directly in papywizard plugin.
Crash analysis system for Microsoft Windows
Fixes :
- 0001134: [Performance] Generic crash analysis system - resolved.
- 0000561: [Editor] Moving image issue with update - resolved.
- 0000932: [Shell Integration] Qt path under linux - resolved.
- 0001028: [UI behavior] Workspace saving leads to crash - resolved.
- 0001128: [Import plugins] Papywizard - Focal length integration - resolved.
Download
http://www.kolor.com/download-autopano- … .html#beta
Take care,
Alexandre
