#1 2012-01-23 22:16:06
Ash.
New to Autopano, need a little help!
Hello everyone,
I would really appreciate some advise on using Autopano 2.6.
Very new to using this software and did my first Pano today, but when watching the first tutorials for choosing the folder and files I do as instructed click the browse folder icon and then select folder and click OK i get a quick flash of a loading bar and the nothing happens at all???
Completely confused MacBook Pro Intel user.
Again, I would really appreciate any advise on what or where I'm going wrong.
Many thanks in advance.
Ash.
#2 2012-01-24 08:54:47
Absolute beginner
Website
Re: New to Autopano, need a little help!
If the browse folder ended up in nothing to be display means perhaps that there are no image in this folder, or all images are in unsupported format ( PSD / PSB mainly ).
#3 2012-01-24 15:22:53
Website
Ash. wrote:
Hello everyone,
Ash.
Hi Ash!
Given you have an "understandable" file-format (TIFF, JPG for example): select all images and drag them into the left window of APG. That´s the "Mac like" way.
Or in the open/import dialog open the folder, select the images and hit "import" or "ok" whatever it is.
In terms of using the app i suggest to get a bit familiar with the tutorial first . . . winkcool
„It’s not creative unless it sells.″ Leo Burnett
