#1 2012-01-16 13:03:08
spitzlbergerj
APG2.6 - Lightroom Export plugin doesn't start APG after exp. images
I tought that the  export plugin within Lightroom 3.6 should start APG after finishing of the export. In my installation the images were exported correctly. But then nothing else happend.
Is it corerct that I have to start APG and to import the exported images manually?
my installation:
Windows 7 Ultimate 64bit
Lightroom 3.6 64bit
APG 2.6 64bit
Thanks a lot in advance
Best regards
Josef
#2 2012-01-16 13:08:49
Absolute beginner
Website
Re: APG2.6 - Lightroom Export plugin doesn't start APG after exp. images
No, Autopano should be launched automatically after export. If not, it's probably an installation issue. Some ideas to test :
- uninstall autopano and reinstall it.
- check that the installation profil used for autopano is the same as lightroom.
