  • Index
  •  » Panogear
  •  » Panogear - Shutter will not fire; head keeps rotating
#1 2011-12-17 05:05:46
bretfrk
When I try to run a mosaic with the papywizard, the head moves to the first picture location, pauses slightly, shutter does NOT FIRE, then keeps rotating around and around till I abort.
The auto-focus is off.  It is in complete manual mode, shooting with a canon 50D.
I connect to the head via Bluetooth.
I test the movement of the head.
I can press the up arrows (the lens points up) and press the left button (the lens points left).
I “set reference” position with the lens pointing at the horizon, straight ahead.  It references 0 Yaw, 0 pitch.  See attached picture “photo.jpg”
I rotate the head with the left button all the way around in a circle back to the reference point, it registers only -180 on the yaw.  ****This seems incorrect.****
I point the head straight upwards, it registers +90.
I set the upper left position of the corner 0 at –37.4 yaw, 32.2 pitch.  This is shooting up and to the left.
I set the lower right position of the corner 1 at 44.5 yaw, -19.2 pitch.  This is pointing down and to the left. See attached photo “photo 2”  The corner 0 is exactly the same angle, but point to the left and up.
When I type in the upper left position “go to” “free”  to back to the initial -37.4 yaw and 32.2 pitch to return to the upper left corner, both the yaw and pitch move, the pitch locks, continues to rotate to the left,  pauses at the initial position, then the yaw continues to rotate to the left, in circles…… until I hit “abort” to stop rotating.
I try the same “goto” reference, it does not return to reference, pauses at different spot on the yaw that it thinks is the reference, then continues to rotate.
When I shoot the mosaic, the target and head moves up and left to the upper left corner, pauses, then continues to rotate on the yaw left until I hit stop.  The upper left starts as yellow, the shutter does not fire, the block does not turn green.
#2 2011-12-17 10:12:38
Website
Re: Panogear - Shutter will not fire; head keeps rotating
Welcome to the forum...
Which version of Papywizard are you using and on which operating system?
Do you have the battery cover fitted on the mount? The problem you describe can be related to external light sources 'upsetting' the optical encoders on the motors.
Edit your post to see the feature - found below the message 'box' - which allows you to upload images.
Uploaded Images
Nikon D40, Nikkor 10.5mm fisheye, Sigma 8mm f3.5 fisheye, Nikkor 18-55/50/35mm  lenses, Nodal Ninja 5 Lite, Agno's Mrotator TCSshort
Nikon P5100, CP5000, CP995, FC-E8, WC-E63,WC-E68, TC-E2, Kaidan Kiwi 995, Bophoto pano bracket
Merlin/Orion panohead + Papywizard on Nokia 770/N800 and Windows XP/2K
#3 2011-12-19 04:20:18
bretfrk
Papy wizard 2.1.21.  The same problem with Windows and Mac.
The batter cover 'almost' closes.  The two lithium batteries prevent it from closing all the way till it locks.
I can't imagine the crack is large enough to let light in.
#4 2011-12-19 04:21:14
bretfrk
Also, I tried the mosaic test with just one photo, and the head will move and trigger the shutter.  It did not trigger before with multiple pictures, or even the first picture of a sequence.
#5 2011-12-19 09:10:39
Website
The problem is with the bubble level; add a black tape under it to prevent light going through.
Canon 20D + 17-40/f4 L USM + 70-200/f4 L USM + 50/f1.4 USM + Tokina 10-17 3.5-4.5 AF DX Fisheye
#6 2011-12-19 15:55:40
bretfrk
Under the bubble level, it is solid plastic.  See second picture.
(Previous posts say the housing is open or the level is visible??)
I placed two pieces of electrical tape, to make sure to overlap the possible gap in the housing.
Did a test shoot, and the first mosaic worked well.  Will try a few more.
Uploaded Images
#7 2011-12-19 19:49:00
Website
Cool!
#8 2011-12-20 02:45:17
bretfrk
Frédéric - thanks for helping me with this...
Well, it is not working again.  Tape is placed per the picture, then taped all the seams on the cover on the top.
It worked on the first pano, but since I have tried shooting another (full manual mode), the same problem has happened again.
I ran a preset and it got about halfway through, on two separate occasions, and stopped on the middle photo, then started rotating around and around.
I tried a shooting a mosaic, the same thing.  Went to the first picture, then started rotating.
#9 2011-12-20 19:05:16
Website
Did you check the batteries?
#10 2011-12-20 21:47:12
bretfrk
batteries are fully charged.  When it was running the mosaic and the preset, there were times where it went two different speeds.  Most of the time it was slow, but it would speed up a few times.
#11 2011-12-21 13:44:41
Website
Does it occur with the hand controller? BTW, did you unpluged it when using the BT module?
#12 2012-01-04 20:08:18
bretfrk
I do not have the hand controller I believe you are talking about - I have the black controller that comes with the head (originally from the orion head).
The bluetooth dongle was attached when shooting the mosaic.
#13 2012-01-05 08:57:49
Absolute beginner
Website
One note : the controller in the panogear are optical controllers. If the backpack is not covering everything ( meaning the internal part of the head is not in the dark ), it won't work.
#14 2012-01-05 11:40:52
Website
dont know it for the panogear (I use a merlin coming from TA Austria...). I had to tape the bottom of my spirit level to avoid coming light into the body....
Online
#15 2012-01-05 12:22:59
Website
Whatever the hand-controller is (the default one, with the 4 arrows and some little buttons, or the big GOTO one, with screen and so), you have to unplug it when using the bluetooth controller. The head can only have *1* device attached.
  • Index
  •  » Panogear
