#1 2011-10-12 23:22:01
firefire
Website
Link 'tick box' for changing dimensions of logos/maps etc.
As in Photoshop, when you change the size of an image, you can link the dimensions, so that as you change one size i.e height, it automatically keeps it in proportion to the length.
Is it possible at some point to have this option when inputting the pixel/percentage dimensions of the logos/maps etc.
I'm just talking about a little tick box or something by the side....should be fairly simple really. It would save me constantly having to go to photoshop to find out what the dimensions should be! (unless I am missing something and it is already there!)
Thankyou!
Neil.
#2 2011-10-13 08:27:56
Administrator
Website
Re: Link 'tick box' for changing dimensions of logos/maps etc.
This option is already there, but "hidden".
If you set 0 for the opposite dimension, the ratio of the original image should be kept.
I agree that it is too hidden to be friendly, and that we should work on a solution like the one you propose.
#3 2012-01-27 19:29:23
vesnice8
Where is "hidden"? where I have to put 0 for the opposite dimensions?
Thanx
#4 2012-01-30 08:27:14
Administrator
Website
Each size field is composed by a height field and a width field.
Set a value in one of them, and set 0 in the other field.
