#1 2011-07-16 14:02:19
sikhoonak
right click
disable right click and about kr pano menu
i have free license panoture pro
how can i do this?
it possible to show me by image?
thanx
#2 2011-07-16 14:41:28
sikhoonak
Re: right click
bal3ad@yahoo.com
nobody help me?
#3 2011-07-18 08:32:58
DArt
Administrator
Website
Re: right click
You can remove the krpano and Panotour entry on right click menu by using a branding free license that you can buy on our store.
However, you will have ever the flash entry menu (due to the plugin flash). As far I know, you cannot add an image as entry but you can add your own entries using PanotourPro (extra menu).
#4 2011-10-27 11:42:23
sikhoonak
Re: right click
how to remove panotour branding after insert a license file?
its automaticly?
#5 2011-10-27 15:08:41
UK Pano
Re: right click
Are you referring to the general KRPANO license or the additional Branding Free license?
#6 2013-01-30 19:11:16
eness3d@gmail.com
Re: right click
Hello our company has just purchased Panotour Pro license but we would like to disable " panotour pro " and " about krpano " , i've tried to use the sub menu Extra -> Licence Branding Free, and load my   .license file but it doesnt work.
If someone knows how to fix that it would be great
thank you
#7 2013-01-30 19:18:36
Website
Re: right click
thank you
ask asked above(in post #5): which .license did you use?
this one: http://krpano.com/buy/brandingfree/ ?
#8 2013-01-30 21:14:56
Website
Re: right click
thank you
Could you please be a bit more specific? From what you write i understand you mean the text which appeares on top of the window-frame of the panorama?
Where do you read "about kroano"?
Or do you mean your application runs in trial-mode and shows watermarks?
#9 2013-01-30 23:43:22
Website
Re: right click
Where do you read "about krpano"?
We are talking about the context menu that appears when you right-click ( or whatver is similar on a Mac).
Uploaded Images
Online
#10 2013-01-31 00:20:19
eness3d@gmail.com
Re: right click
Hello ,
@Klause: sorry i wasnt clear enough, I was indeed refering to the context menu ( right click on the panorama )
@gkaefer: I m using PanoTour Pro 1.8 (registered) , but it seems that the pro version isnt enough to disable Context menu and it require another licence file that cost 299€.
Thank you for your help
#11 2013-01-31 01:20:05
Website
Re: right click
Hello ,
Ok - thank you! I thought you referred to the text above the pano or in the window-frame.
