#1 2011-07-12 15:08:07
Absolute beginner
Website
Autopano Engine v2.6 Beta 1
If you follow the blog, you already saw this huge update. So first, for details, look here for the videos, it explain more any text here :
http://www.kolor.com/blog-en/2011/07/12 … -6-beta-1/
The main new features:
- integration of Autopano Giga into third-party software (Adobe Lightroom 3.x, Adobe Bridge CS3, 4, 5 and 5.1, Apple Aperture 3, Google Picasa 3) — Autopano Giga only
- new generation of Neurone, the optimization engine of Autopano: it is now 3 to 10 times faster on fisheye images and offers an improved lens model
- better support for multi focal lengths with a priority given to the long focal lengths to keep all their pixels
- better color homogenization in blender.
Take care
Alexandre
#2 2011-07-13 12:42:05
hbschwartz
Re: Autopano Engine v2.6 Beta 1
i downloaded the beta version of autopano and autopano giga and it asks me to put in my registration information.  do we have to buy the beta. if not, shouldn't the software automatically update our registration data?
#3 2011-07-13 14:07:55
Absolute beginner
Website
This version works side by side with 2.5 release. That's why you need to enter again your registration. No harm will be done to a working 2.5 version.
#4 2011-07-13 21:13:02
dvine
The rendering works from within LR with problems.
The Rendered file (two source images) does not appear in the folder within the lightroom database from which the source images were obtained. Instead it ends up in a dektop folder called unnamed export and I have to drag it into lightroom. I have set the preference directory to %i
I have no idea why intermediate jpeg files are created.
#5 2011-07-14 13:31:25
Website
Alexandre,
Where do you want people to report bugs and comments on this release?
Do you plan to create a new forum topic for 2.6 bug reporting and discussion?
Nikon D40, Nikkor 10.5mm fisheye, Sigma 8mm f3.5 fisheye, Nikkor 18-55/50/35mm  lenses, Nodal Ninja 5 Lite, Agno's Mrotator TCSshort
Nikon P5100, CP5000, CP995, FC-E8, WC-E63,WC-E68, TC-E2, Kaidan Kiwi 995, Bophoto pano bracket
Merlin/Orion panohead + Papywizard on Nokia 770/N800 and Windows XP/2K
Online
#6 2011-07-14 23:30:08
hub
Website
Mon installation de la version Mac a échoué. Que dois-je faire? L'erreur s'est produit lors de l'installation.
#7 2011-07-15 04:56:57
Website
D.
Whjy are you posting about PTP 1.6 in a topic for the announcement of APP/APG 2.6 beta 1?
Online
#8 2011-07-15 04:58:07
Website
oh... sorry.. where should I be posting it...
D...roll
mediavets wrote:
D.
Virtual Tours and 360 Object Products Photographer - Our aim is to create a 3D Virtual Shop Tour with links to 360 degree products.
VR Drive II - D90 - Nikon 10.5 fisheye - Nikon D800 with Nikon 14-24.
#9 2011-07-15 05:04:11
Website
D...roll
Choose whichever of the topics in the Panotour/Panotour Pro section of the forum seems best to reflect the subject matter of your post.
Online
#10 2011-07-19 04:17:23
mlearmonth
In version 2.6 beta 1, on the Picture Edit screen, I cannot input the Location: Yaw, Pitch, Roll and FOV digitally (as was possible in version 2.5.2).   I can only change its location by pushing the photograph tile around with the mouse.
Mike Learmonth
#11 2011-07-19 12:10:59
mawa_73527
aperture plugin works great. Fisheye rendering is very fast
#12 2011-07-20 02:01:55
mlearmonth
Is there an updated manual for Autopano v2.6 Beta 1 (or am I crazy to be asking such a question on a beta version - LOL)?
Mike Learmonth
#13 2011-07-20 15:00:27
Gordon
Hi Alexandre,
The speed improvements of Autopano Giga are great, lightning fast, and the integration with external applications is amazing smile
Can you please give us some info on what 2nd and 3rd order distortions are?
TIA
Best
Gordon
2000th Member big_smile
GigaPixel Experimenter
