#1 2011-07-04 12:18:43
pns
possible problem with cable?
greetings!
i'm the new owner of a panogear kit, but i cannot fire a canon camera, no matter what i try.  what i've done:
- the head moves (no mechanical problems)
- the head fires a nikon camera (so the snap jack appears to be fine)
- the canon can be fired by a regular shutter cable release (so the camera jack appears to be fine)
- the problem exists with both the bluetooth thingy under papywizard and the touch control (so it's not a settings problem in papywizard)
i usually assume i'm doing something wrong, but in this case i'm pretty sure it's the canon cable that was provided.  what can i do?
cheers,
pns
#2 2011-07-06 14:55:31
pns
Re: possible problem with cable?
just a quick update...
soon after my original post, a reply appeared relating a similar problem with a canon cable, but it soon disappeared...?
in the absence of feedback in the forum, i've sent a couple of emails to the kolor team, explaining the situation and asking for a replacement cable.  no reply, so far sad .
i can't use the panogear kit with the camera i bought it for, so i'm rather unhappy about the situation.  i understand the lack of response from the community (after all, it is not your job), but i am very disappointed by the lack of feedback from the kolor people.
cheers,
pns
#3 2011-07-21 10:58:41
pns
further (final?) update:
i've received a new canon cable -- thanx, kolor! -- and the head can finally fire the camera.  it's not entirely consistent (meaning, sometimes it doesn't work), but at least it works most times.
cheers,
pns
#4 2011-07-21 12:48:35
Website
cheers,
pns
Try increasing the Pulse width high value - I set mine at 500ms.
Uploaded Images
Nikon D40, Nikkor 10.5mm fisheye, Sigma 8mm f3.5 fisheye, Nikkor 18-55/50/35mm  lenses, Nodal Ninja 5 Lite, Agno's Mrotator TCSshort
Nikon P5100, CP5000, CP995, FC-E8, WC-E63,WC-E68, TC-E2, Kaidan Kiwi 995, Bophoto pano bracket
Merlin/Orion panohead + Papywizard on Nokia 770/N800 and Windows XP/2K
