#1 2011-04-12 16:12:52
lorenzzz
Problem with camera trigger
Hi , I'm using a canon eos 550 d with the cable rs-60e3. I configuered the camera as the panogear manual explain but the shutter of the camera doesn't work at all . In the manual it is said :
Camera/lens
The "camera/lens" tab allows you to modify the width of the shutter
triggering pulse generated by the motorized head (if the camera triggers
more than once, reduce the pulse. If, on the contrary, the camera does not
trigger, increase the duration).
I don't understand what value I have to change in order to increase the duration of the trigger .
Thank you very much for your help.
Lorenzo
#2 2011-04-12 16:35:21
vincen
Website
Re: Problem with camera trigger
first is your camera setup in manual mode ? as sometimes focus can prevent trigger to work ! if you push on trigger button of camera does it work ?
Vincèn
Blog: http://www.skivr.com
My shop for panoramic photographs: http://magasin.skivr.com
Nodal Ninja 5 R-D16 on Benro Tripod + Ultimate R1 on Nodal Ninja P2 + Nikon D3X/D3/D90 + Nikkor 10.5 + Nikkor 14/24 f/2.8 + Nikkor 70/200 f/2.8 + Sigma 150-500
Panogear + Papywizard sur Neo
#3 2011-04-12 16:51:07
lorenzzz
Hi Vincen ,
I put the camera on manual mode and doesn't work
the cable rs-60e3 it works if i push the botton
Lorenzo
#4 2011-04-12 17:11:16
Website
Camera/lens
Lorenzo
Change this value - this is duration that the switch on the camera port is closed.
Uploaded Images
Nikon D40, Nikkor 10.5mm fisheye, Sigma 8mm f3.5 fisheye, Nikkor 18-55/50/35mm  lenses, Nodal Ninja 5 Lite, Agno's Mrotator TCSshort
Nikon P5100, CP5000, CP995, FC-E8, WC-E63,WC-E68, TC-E2, Kaidan Kiwi 995, Bophoto pano bracket
Merlin/Orion panohead + Papywizard on Nokia 770/N800 and Windows XP/2K
Online
#5 2011-04-12 17:12:15
Website
lorenzzz wrote:
Hi Vincen ,
Lorenzo
Vincen means manual focus in this instance not manual exposure mode.
Online
#6 2011-04-12 17:27:42
lorenzzz
I changed the pulse width value,  I put even 900 ms but still doesn't work at all !!
#7 2011-04-12 17:30:22
lorenzzz
@ Andrew : yes I meaned manual focus too !
Lorenzo
#8 2011-04-12 22:56:59
lorenzzz
Hi, I tried to change the  pulse values, I tried any possible combination but It doesn't work ... Do you think that is a panogear hardware problem ? Should I send It back to kolor  ?
I hope somebody can help me.
Lorenzo
#9 2011-04-13 07:36:09
Website
Do you have a multimeter? Can you try to check if the 'contact' is closed during the shutter pulse?
Canon 20D + 17-40/f4 L USM + 70-200/f4 L USM + 50/f1.4 USM + Tokina 10-17 3.5-4.5 AF DX Fisheye
#10 2011-04-13 09:14:34
lorenzzz
@ Frederic
I have multimeter, can you explain where do I have to put the instrument ? It is said that if I open the panogear hardware warranty will expiere..
Should I test the cable rs-60e3 or something else ?
Thank You
Lorenzo
#11 2011-04-13 10:34:50
Website
Use your multimeter as a diode measurement instrument (the internal contact is an optocoupler). Connect it on the jack, and check if you see the contact closing (you should read the drop voltage of a diode, about 0.6V; check in both directions).
#12 2011-04-13 16:06:53
lorenzzz
Hi , I used multimeter and finally I understood that the cable rs-60e3 is useless with panogear. I bought because of it is said in the camera compability page  http://www.kolor.com/panogear-motorized … ility.html .
If you have a canon eos 550 d you just need the simple cable with the 2 jack included in panogear pack.
Thank you any way (frederic,andrew,vincen).
Lorenzo
#13 2011-04-13 16:14:10
vincen
Website
Right the original trigger cable included with Merlin head is ok for Canon jack cameras big_smile
Vince
#14 2011-04-13 17:24:51
lorenzzz
The webmaster should upload teh page http://www.kolor.com/panogear-motorized … ility.html  related to canon ,
taking  off the  CANON (Connectors) RS-80N3 RS-60E3   if   the original trigger cable included with Merlin head is ok for Canon jack cameras ..........
Lorenzo
#15 2011-04-13 19:57:14
Website
Lorenzo
I believe that higher end Canons require a different cable from that needed for lower end Canons.
Online
#16 2011-12-28 09:00:07
bryankal
I think check your camera setting. some problem occurs due to camera settings not proper with your flash.
