#1 2011-04-07 09:20:04
panopirate
Is there a way to replace a pano in a project with all hot spots stay?
i want to change all my pano's  to smaller size jpegs. can i swap them somehow without redoing all my hot spots and links?? thanks.
#2 2011-04-07 10:24:22
vincen
Website
Re: Is there a way to replace a pano in a project with all hot spots stay?
easier way would be just to replace the pano file in project but if you change resolution of file all hotspots will be messed sad Why do you want to use smaller jpeg ?
Vincèn
Blog: http://www.skivr.com
My shop for panoramic photographs: http://magasin.skivr.com
Nodal Ninja 5 R-D16 on Benro Tripod + Ultimate R1 on Nodal Ninja P2 + Nikon D3X/D3/D90 + Nikkor 10.5 + Nikkor 14/24 f/2.8 + Nikkor 70/200 f/2.8 + Sigma 150-500
Panogear + Papywizard sur Neo
#3 2011-04-07 19:35:02
digipano
Lately even I faced a similar situation where the client wanted an option for slower speed connection asking to do a smaller tour but this means redoing the entire tour, I haven't yet tried resizing the files in the project but an ideal solution would be to configure the output size inside panotour.
#4 2011-04-07 21:41:25
panopirate
It was because the version i made was too big for a website so it needed downsizing. What do you think an optimum MB size is per pano, for good quality reso but still good net speed to view? thanks for your replies.
