#1 2011-03-21 02:24:50
konakid
PTP Project Saved as PT Project
This software is a little goofy. After getting everything licensed and having some things working that didn't work in the trial version, like the progress bar, I now have another problem.
When I save a project in PTP, it is saved as a PT project. So when I open it I am taken to my trial version of PT. The saved file icon indicates it is a PT project and not  PTP project. What is going on???
I'm on a Mac.
#2 2011-03-21 08:07:48
Website
Re: PTP Project Saved as PT Project
Have you removed/uninstalled PT?
#3 2011-03-21 09:08:01
konakid
No I haven't. I was going to but couldn't think why that would cause PTP to save in that mode. I'll do it and see if that makes a diff.
#4 2011-03-21 09:32:30
konakid
Andrew, that seemed to do the trick. Although I am still puzzled as to why.
