#1 2011-03-20 06:46:10
konakid
Text and Field and Field Colors in PanoTour Pro
I have been using AutoPano Tour and wanted to upgrade to PanoTour Pro. However, after downloading the trial to my 17" MacBook Pro, I found it very difficult to work with all the grey text on grey backgrounds. When changing some fields, another grey box appears making it almost impossible to see the numbers on this high resolution laptop screen. The text is already small enough.
I stopped trying to use it after about 15 mins. Is there anyway to make it easier to read? Please help?
Please notice the "Delay" and "Margin" Fields in the examples below, and how difficult it is to see the numbers when changing values.
(And I am not interested in changing the screen resolution to a non-native res, so that is not an option)
Uploaded Images
#2 2011-03-20 07:21:39
Website
Re: Text and Field and Field Colors in PanoTour Pro
If you are in an experimental mood then you could try editing the UI style sheet.
Enter Ctrl+u to open the UI style sheet editor.
Uploaded Images
#3 2011-03-20 07:32:41
konakid
Thanks, I recognize your name from another forum. I'm on a Mac, but Command "u" got me to that window. I've never been there before. I'll give it a try.
While I have your attention. I'm having trouble moving a hot spot "point," after I have done a few other things. Should I be able to go into editor and move a previously placed point, or do I have to delete it and start and link all over again?
#4 2011-03-20 07:48:02
Website
click on the 'add point' again.. you can move them to where you want....
D
#5 2011-03-20 08:13:57
konakid
Thanks Destiny, That did the trick. smile
#6 2011-03-20 12:18:52
Website
Where the hell does that editor come from? Never heard of it! Nice to learn it´s there . . .
thanks, Andrew
#7 2011-03-20 12:49:09
Website
thanks, Andrew
It exists in APP/APG 2.5 too.
You may recall my complaints about how much harder I find it to work with the new 'black-n-grey look'?
Alexandre then provided access to the UI stylesheet editor - he also said they'd develop and offer an alternative 'old style UI' stylesheet, but that never happened.
#8 2011-03-20 13:02:41
Website
mediavets wrote:
. . but that never happened.
Yeah - i remember well . . . cool
But - where can i find it in APG 2.5 resp. 2.5.1
#9 2011-03-20 13:05:43
Website
I remember you telling us weeks ago about that... I played with it but I rather like the setup colour etc so I left it... but nice to know it was there...
#10 2011-03-20 13:06:30
Website
Ctrl+u in Windows - I guess that's Cmd+u on Macs?
#11 2011-03-20 13:08:24
Website
Correct!
#12 2011-03-20 14:21:45
Website
Andrew, Destiny!
Thanks!
#13 2011-03-20 22:15:29
konakid
Maybe someone could edit this and make it more "eye friendly" and then give us the corrected code. smile
Or perhaps Kolor could do it for us. I am still debating which tour software to purchase and this is definitely a concern. I'm having enough trouble sorting out the various "quirks."
#14 2011-03-21 09:13:30
DArt
Administrator
Website
The Ctrl+U command is generally used by us to debug the UI colors/margin and others UI tricks. The modifications made cannot be save directly in the UI. However, this files can be edited by hand at your own risks (*.qss files in .../Application Data/.../Kolor/UI ).
We planned to make a second skin (lighter) in near future...
#15 2011-03-21 09:25:37
Website
I have looked at ptp etc on a pc and it is a bit dark but on my Mac it looks great so please do not take that away... Most pro 3D software apps have the same skin colour... which makes the software look more professional...
D
#16 2011-03-21 09:27:23
konakid
"planned" ???
Does that mean the the plan is on or off? smile Another skin would be great.
#17 2011-03-21 09:31:04
konakid
D
Destiny, you must have an iMac or a larger monitor. Try it on a newer MacBook Pro with a 1680 x 1050 res on a 17" screen.
#18 2011-03-21 11:38:20
DArt
Administrator
Website
konakid wrote:
"planned" ???
Sorry, I mean a second skin is in progress for a next release wink
#19 2011-03-21 11:59:15
konakid
DArt wrote:
konakid wrote:
"planned" ???
Thanks, that would be appreciated. smile
#20 2011-03-21 12:26:50
Website
Do you color-manage your Mac? Was the PC color-managed?
#21 2011-03-21 20:25:04
konakid
I have custom calibrated my MacBook Pro, and the APG and PTP color scheme is a little easier to see with that setting than the other two default gamma calibrations. But I have to turn the brightness up all the way.
I haven't checked yet on my iMac - but I'm sure it will be a lot easier to see.
