#1 2011-03-16 11:21:16
davemack
_self problem
Hi, can you help. I am rebuilding my website and having trouble linking a hotspot to a url and open on the same page. I was just adding ',_self' to the end of the address line for the link with the previous version of panotour but this does not seem to work now.
#2 2011-03-16 19:37:28
MikeMcFarlane
Website
Re: _self problem
Hi Dave
That should work according to the openurl documentation at http://krpano.com/docu/actions/
Code:
openurl(url,target*)
Open an external url.
Note - this action requires the External Interface of the Flashplayer! This means the action will work offline/locally only when the security settings of the Flashplayer were adjusted. See here for more detatils - Local / Offline Usage.
Parameters:
url
The url to open.
target (optionally)
The target where the url should be opened.
Possible settings:
_blank - open the url in a new window (the default)
_self - open the url in a current frame in the current window
_parent - open the url in the parent of the current frame
_top - open the url in the top-level frame in the current window
Examples
 openurl('http://krpano.com',_self);
openurl('help.html');
Is the rest of the syntax right? Post the line if you want.
Mike
Bio: Generation fluxer - farmer, mechatronics engineer, project manager, climbing shop manager, landscape photographer, programmer, virtual panographer, cyclist, life lover.
Twitter: MikeJMcFarlane
email: moo@moosooboo.com
www: www.moosooboo.com
#3 2011-03-16 20:33:28
davemack
Re: _self problem
Thanks for trying to help. I have been using previous versions of Autopano Tour without a problem linking a hotspot to another of my own 'web pages' on the same server. I have just been inserting the http web address in the url 'hotspot properties' area. I then always just added ,_self after the web address. Now I have upgraded to v1.5 Panotour Pro this no longer works, it just links to a 'page not found'. If I remove the ',_self' It does link to the web page but in a new browser window.  I really don't know anything about scripting to go meddling to much....the older versions worked, the new version doesn't...
#4 2011-03-16 23:19:15
Website
Re: _self problem
That's my experience too.
I don't think anyone from Kolor has yet acknowledged this bug?
#5 2011-03-17 08:46:51
DArt
Administrator
Website
Re: _self problem
You are right, there is some trouble with ",_self" at end of URL.
We put some ' ' around URL now to avoid to errors if user put some strange character in URL (we have some case before).
However, you can bypass it by putting in URL field:
Code:
http://www.kolor.com','_self
Note the ' ' around the ','. I have tried it this morning with success. I add a note to enhance that in future version. (issue 620 opened)
#6 2011-03-25 01:24:14
Website
Re: _self problem
I did what you suggested on my project and its worked, great!!... Thank you wink
Would you have any suggestion on how to put an image to .. distorted=''true'' .. for an iDevice....??
D
Code:
#7 2011-03-25 10:18:21
DArt
Administrator
Website
Re: _self problem
It is not yet supported by KRPano.
