#1 2011-02-21 15:04:47
Adolfo_360vista
Panotour Pro 1.5 ... License KrpanoJS PROBLEM !
Hi there !
I´ve purchased Panotour Pro (299 € plus VAT) ... I´m making a virtual tour for iPad/iPhone and when I check it on safari appears the watermark at the center saying: KrpanoJS Demo version !
Please help me ... I supossed that license was included at the software pack. Even I wrotte a e-mail Kolor contact asking for this issue and I did not have response...
I love this new software and I bought it for make iPad / iPhone virtual tours. Please help me !
Thanks in advance
Regards,
Adolfo Rancaño
http://www.360vista.es
#2 2011-02-21 17:50:12
Website
Re: Panotour Pro 1.5 ... License KrpanoJS PROBLEM !
Adolfo,
Welcome to the forum...
Yes, the iDevice compatible tour creation capability is built-in with Panotour Pro.
Which version are you using (32-bit/64-bit) and on which OS platform?
You have registered your licence key in Panotour Pro?
When you are checking with Safari are you checking from local disk or an online tour?
#3 2011-02-21 21:04:01
Adolfo_360vista
Hi mediavets !!!,
thanks for your replay !,
The problem is half-solved ! ;-)
- I´m mac user (64 bits)
- I have registered the license key at the software
The good news is that the watermark has disappear (sorry for my english !) but the BAD NEWS is that when I upload ALL files to my server-hosting I can´t see anything. The check out on LOCAL is Ok even emulating iPhone with Safari (and without watermark)
The link is this:
http://www.360vista-studio.com/westinva … vices.html
I appreciate your help, thank you very very much !!!
Adolfo
#4 2011-02-21 22:24:02
Website
It looks as if file permissions on some of the files may be set so that they cannot be read or executed.
Is that possible?
Are you sure you have uploaded all the files created when exporting the tour and that have maintained the same folder/file structure?
#5 2011-02-21 22:40:06
Adolfo_360vista
Hi mediavets,
Yes, ALL archieves are uploaded. I upload with Cyberduck (ftp client) ... is possible that the permissions (read, write, etc.) are bad configurated. I never touch this parammeters, I upload by default.
It seems like you said, is a permmisions problem ... I now this is difficult to answer but how can I solve this issue ? ... Any idea ?
Thanks a lot REALLY !!
Adolfo
#6 2011-02-21 22:44:52
Website
Adolfo_360vista wrote:
Hi mediavets,
Adolfo
I expect your FTP client allows you to change (CHMOD) file permissions?
If so try setting permission on all files that make up the tour to 777 - no restrictions on read, write or execute.
#7 2011-02-22 00:02:58
Adolfo_360vista
EUREKA !!!,
the problem was the permissions !. My FTP client changed all the permissions and most of them was not allow "read" it ... uffffsss !!!
Now I changed the preferences of my FTP client and I hope in the future don´t have anytime this conflict.
THANKS THANKS A LOT my friend !!!
Now I have to work to change a lot of things in my tour but I´m very happy.
Greatings from Spain !
Adolfo.
#8 2011-02-22 00:03:52
Website
hmm...
do I miss something?
if I klick the link I get this pano? just seconds ago....
ok... see my mail was some seconds after heureka ;-))
Uploaded Images
