#1 2011-02-08 04:51:40
wcough
Purchased panotour pro problem embedding video
Just purchased panotour pro and in a pano pic there is a tv that I placed the hotspot to play video on the tv
it display but video is mirroed and sideways,,, I converted video to diffrent formats flv swf mp4, all same results
plays fine in lightbox type as link but wanted it to play automatically in tour correcly and not mirrored/sideways
any help
wcough
#2 2011-02-08 06:49:33
Website
Re: Purchased panotour pro problem embedding video
Welcome to the forum...
I guess you are using a rectangular hotspot and selecting the video as a Display/Object?
If so you need to draw the rectangular hotspot in a particular sequence to obtain the correct orientation of the video.
Start at the top left corner and proceed in a clockwise sequence - top left, top right, bottom right, bottom left - and the video will display with the correct orientation.
#3 2011-02-08 08:14:53
wcough
Solved Tried just now,,,, And yes that was the issue
Thanks,, I searched prior but didn't see that in the forum
Again thank you
wcough
