Pages: 1
1) As far as I understand it having several layers (as a rule one layer for each of the exposure levels) is required for Exposure Fusion and is required for HDR. These options should be grayed in the Render window when a single layer only was defined.
2) For Exposure Fusion, when source images were shot so that every source images pertaining to the same layer are sharing the same exposure setting then NONE (disabled) color mode is to be selected.
3) For Exposure Fusion, when source images were shot so that source images pertaining to the same layer DO NOT share the same exposure setting then LDR color mode is to be selected and a yellow anchor is to be set in each of the layers.
4) I always open the Level tools and click the Auto button before adjusting Exposure Fusion settings but I don't know whether or not this is preferable.
5) Using the gamma setting in the level tool is helpful for Exposure Fusion but I suppose that for HDR a gamma value of 1 is the only recommendable value.
6) To produce a .exr or a .hdr file it seems that:
- HDR must be selected for the color mode in the edit window
- HDR output must be selected for the Blending preset in the Render window
- EXR by ILM or HDR Radiance is to be selected for the file format in the Render window
Having to specify the same thing in three different places is a regretable source of error...
These points suggest that Exposure Fusion and HDR are difficult to test with the RC2 as it is. A simplification of the settings is desirable. This would help to avoid setting inconsistencies. This would help to make the corresponding documentation both easier to write and easier to read and follow.
Issue 544 opened
You understanding seems good.
We are writing a documentation to explain needing settings in HDR mode (and LDR too).
In most of cases, if you want HDR files you have to use HDR color correction, Output HDR preset and chose a HDR file format.
We do not automate all these settings because some particular samples need to change one of these parameters.
For future software evolution, we are thinking about global presets which will automatically set all theses parameters for standard workflow (as HDR export from LDR bracketed pictures).
The main question is whether or not users must understand how it works. Another issue is how to name the settings (usual names must be taken into account, though they are not alway the best possible ones.)
HDR is an interesting example:
- this name is used both for recording (that is recording a wider brightness range than the one a given camera sensor can record) and for image rendering (where several methods can be used to establish the correspondence between what was recorded and what is displayed, global tone-mapping, local tone-maping, fusion, etc.)
- to get the well-known "HDR look" some enjoy and others dislike, local brightness changes (like when using PS Shadow/Highlight) are enough, recording a high dynamic range is not mandatory.
- I don't know why Autopano HDR color setting is to be used because, as far as I know, Autopano always use floating point numbers.
- I understand that to produce 32bit image files several layers are to be fused in a single resulting image so that I should not be surprised to see that Exposure fusion is automaticaly selected when HDR Output is selected as a rendering format.
- I don't know why Remove ghosts is selected for Exposure Fusion but Remove HDR ghosts is selected for HDR Output.
- I suppose that selecting a 32bit file format when neither HDR color mode nor the HDR Output were selected is useful in some rare occasions
- stacks could be named "HDR stacks" or "bracketing stacks" but this should include distance bracketing (for large DOF) and event bracketing (when something changed while the pano was recorded.)
Les premières voitures auxquelles je me suis intéressé comportaient un réglage de l'avance à l'allumage sur le tableau de bord mais il n'y en avait plus sur la première que j'ai conduit. Elle comportait encore une tirette nomée "starter" pour augmenter la richesse du mélange qu'il vallait mieux actioner les jours de grand froid.
Maintenant il y a un micro-processeur pour optimiser ces réglages ![]()
Quite all questions should be covered by the documentation.
See the Work in progress ( in french ) here : http://www.autopano.net/wiki-fr/action/ … o_Giga_2.5
LDR / HDR : Comment ça marche wrote:
Il est toujours très compliqué de parler de HDR en photographie car ce terme à trop de sens ( est-ce une image, est-ce une chaîne de production, est-ce un outil, etc ). Dans notre cas, nous allons donc plutôt parler de ce qu'on a en entrée ( des images ) et de ce qu'on veut en sortie ( un ou plusieurs panorama ).
Il est toujours très compliqué de parler de HDR en photographie car ce terme à trop de sens (est-ce une image, est-ce une chaîne de production, est-ce un outil, etc.) Dans notre cas nous allons donc plutôt parler de ce qu'on a en entrée (des photos) et de ce qu'on veut en sortie (un seul panorama ou au contraire plusieurs panoramas, un pour chaque niveau d’exposition.)
Bracket - Utiliser les piles wrote:
Autopano permet d'utiliser une prise de vue en bracket et d'en conserver les spécificités, c'est à dire, de superposer parfaitement les différentes expositions d'une même image afin de les assembler pour obtenir les panoramas correspondants aux expositions respectives de la prise de vue (le principe est le même pour le bracketing de focus ou le bracketing d'ouverture).
Ceci est évidemment très intéressant pour l'assemblage d'images bracketées. Les panoramas bracketés obtenus peuvent être mélangés comme bon vous semble (en utilisants les masques Photoshop... etc...).
Autopano permet d'utiliser une prise de vue basée sur le bracketing et permet d'en conserver les spécificités, c'est à dire de superposer parfaitement les différentes variantes d'une même image afin de les assembler et d'obtenir les panoramas correspondants aux photos prises avec des réglages différents (ça s'applique au bracketing de la profondeur de champ comme au bracketing du temps d'exposition.)
Ceci est évidemment très intéressant pour l'assemblage de photos bracketées: on obtiendra une variante du panorama pour chaque niveau de bracketing, ces variantes pouront être en suite mélangées avec l'application que vous préférez (en utilisant Photomatix [ou Enfuse], les masques Photoshop quand quelque-chose a bougé, CombineZ pour augmenter la profondeur de champ, etc...) Comme ce mélange final dépendra souvent d'une appréciation plutôt que d'un choix technique il est utile que ce soit la dernière étape: on peut essayer plusieurs variantes sans recommencer l'assemblage.
___
Remarque à propos des piles (ou des tas, mais parler d'une pile de photos me semble mieux adapté que de parler d'un tas de photos!) ces piles sont aussi utilisées pour indiquer qu'on veut ou pas des liens à l'intérieur de chaque pile de photos et pour indiquer si on préfère des liens entre les photos qui sont au sommet des piles uniquement ou si on en veut entre tous les niveaux. Il vaut probablement mieux expliquer ça sur une autre page.
Autre remarque, à propos du bracketing : la fusion est le seul cas de où le mélange des calques réalisé par Autopano à partir d'un bracketing a pour but de donner directement l'image finale. Dans les autres cas le résultat est un fichier 32 bits ou un fichier multi-calque non définitif. Ca me semble un trés bon choix: les trucs compliqués dans les applications faites pour ça, la solution la plus accessible disponible dans Autopano !
A ce jour l’ambiguïté sur "groupe" n'a pas été complètement supprimée (les groupes ne sont visibles que dans la fenêtre principale, là où on voit aussi les piles -- les calques et l'éditeur de calques étant accessibles dans l'éditeur de panoramas et dans la fenêtre Rendu.)
Quand l'outil Ancres (ou "pins" en anglais) est actif on peut voir (c'est important) et même changer (mais c'est secondaire) le type de correction (exposition, gamma, tonalité) de chaque photo. Ca n'est pas dit et ça n'est pas montré dans les captures d'écran.)
Oui, certains screenshots sont encore à mettre à jour, c'est juste.
Si, l'ambiguité groupe a été totalement levée. L'editeur de groupe => editeur de calque ( et calque sera utilisé partout ).
On parle de groupe qu'avant la détection.
On parle de couche pour la couche alpha ou rouge, vert, bleue.
Pages: 1
COMMUNITY Forums Blog |
