#1 2011-01-18 07:30:25
mawa_73527
shutter release is not workong
I can control the pano gear via BT module. But I simply cannot get the Panogear to trigger a shutter release. Is there anything else I need to be taking into consideration? Camera Nikon D700.
Here is the log:
Code:
2011-01-17 19:35:00,967::Shooting::INFO::Start shooting process...
2011-01-17 19:35:00,971::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.pyc", line 517, in start  File "papywizard/model/data.pyc", line 266, in createHeader  File "papywizard/model/data.pyc", line 179, in _serializeIOError: [Errno 2] No such file or directory: u'/Users/jeremypronk/papywizard_%(date_time)s_%(mode)s.xml'
2011-01-17 19:35:00,971::Shooting::ERROR::Shoot process failed
2011-01-17 19:35:01,904::Shooting::INFO::Start shooting process...
2011-01-17 19:35:01,908::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.pyc", line 517, in start  File "papywizard/model/data.pyc", line 266, in createHeader  File "papywizard/model/data.pyc", line 179, in _serializeIOError: [Errno 2] No such file or directory: u'/Users/jeremypronk/papywizard_%(date_time)s_%(mode)s.xml'
2011-01-17 19:35:01,908::Shooting::ERROR::Shoot process failed
#2 2011-01-18 07:31:26
mawa_73527
Re: shutter release is not workong
here another log
Code:
2011-01-17 19:58:23,283::Shooting::INFO::Start shooting process...
2011-01-17 19:58:23,297::Shooting::INFO::Moving
2011-01-17 19:58:23,557::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:23,557::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:23,800::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:23,801::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:24,060::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:24,061::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:24,301::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:24,302::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:24,543::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:24,544::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:24,785::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:24,786::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:25,065::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:25,066::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:25,306::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:25,307::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:25,547::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:25,548::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:25,790::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:25,790::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:26,055::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:26,056::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:26,298::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:26,298::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:26,546::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:26,546::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:26,787::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:26,788::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:27,052::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:27,053::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:27,295::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:27,296::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:27,537::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:27,538::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:27,812::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:27,812::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:28,055::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:28,057::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2011-01-17 19:58:28,297::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:28,298::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:28,540::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:28,540::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:28,805::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.pyc", line 236, in _sendCmd  File "papywizard/hardware/serialDriver.pyc", line 114, in sendCmdIOError: Timeout bei seriellem Lesevorgang
2011-01-17 19:58:28,806::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2011-01-17 19:58:28,807::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.pyc", line 619, in start  File "papywizard/hardware/head.pyc", line 194, in stopAxis  File "papywizard/hardware/axis.pyc", line 373, in stop  File "papywizard/hardware/axis.pyc", line 402, in waitStop  File "papywizard/hardware/axis.pyc", line 273, in read  File "papywizard/hardware/axis.pyc", line 243, in _sendCmdHardwareError: Axis 1 can't send command
2011-01-17 19:58:28,807::Shooting::ERROR::Shoot process failed
#3 2011-01-18 10:32:27
mawa_73527
anyone can help?
#4 2011-01-18 12:21:41
Website
Please, use the 'code' tag to include traceback, and try to keep the carriage returns; it is easier to read...
In the first traceback, I one can see:
Code:
Double check you are using the correct path for the data file, in the 'Configuration' dialog, 'Data' tab, 'Data Storage dir' param:
http://www.papywizard.org/wiki/UserGuideSvn#Datatab
#5 2011-01-18 21:36:20
mawa_73527
I changed the path and nothing happened I got the same error messages I found the file papywizard_%(date_time)s_%(mode)s.xml in the new folder I had created.
Or do I need to create a folder called:jeremypronk under user?
#6 2011-01-19 00:09:47
Website
You don't need to create a new dir; just make the 'Data Storage dir' param on a valid dir (use the button to open the dir selector, and pickup whatever existing dir - a dir where you can write).
BTW, do you mean you found a (empty?) file named 'papywizard_%(date_time)s_%(mode)s.xml' on your file system? You should not; the %(date_time)s part should be replaced by the current date an time, and %(mode)s by 'mosaic' or 'preset', according to the mode you chose to shoot your pano...
#7 2011-01-19 09:26:17
mawa_73527
I found a 'papywizard_%(date_time)s_%(mode)s.xml'! This was an xml file with all the information about the shots that were to be made!
this is the info inside the xml file:
from what I understand this info is what I defined in papywiz
Code:
<?xml version="1.0" encoding="utf-8"?>
<papywizard version="a">
    <header>
        <general>
            <title>
                Here goes the title
            </title>
            <gps>
                Here goes the location
            </gps>
            <comment>
                Generated by Papywizard %(version)s
            </comment>
        </general>
        <shooting mode="mosaic">
            <headOrientation>
                up
            </headOrientation>
            <cameraOrientation>
                portrait
            </cameraOrientation>
            <stabilizationDelay>
                0.5
            </stabilizationDelay>
            <startTime>
                2011-01-18_21h42m51s
            </startTime>
            <endTime>
            </endTime>
        </shooting>
        <camera>
            <timeValue>
                0.5
            </timeValue>
            <bracketing intent="exposure" nbPicts="1"/>
            <sensor coef="1.0" ratio="3:2"/>
        </camera>
        <lens type="rectilinear">
            <focal>
                20.0
            </focal>
        </lens>
        <mosaic>
            <nbPicts pitch="1" yaw="4"/>
            <overlap minimum="0.25" pitch="1.00" yaw="0.44"/>
        </mosaic>
    </header>
    <shoot/>
</papywizard>
#8 2011-01-19 12:35:08
Website
There seems to be a nasty bug, preventing Papywizard to replace all the substitution strings (%(xxx)s) with the correct values. Starting with the filename itself!
Be patient, some people are working on Papywizard MacOS packaging, and a more up-to-date release should come soon!
#9 2011-01-21 12:40:40
Website
Ok, can you do the following things:
Start Papywizard
Connect to the head
Shoot a single-image pano
Open the Help -> View Logs menu
Save the lgos and post it here.
