| User list | Rules | You are not logged in.
This is the second beta build of PanoTour with a lot of bug fixes but also some really nice new features ![]()
changes:
* File extension project replaced by kpt (apt may still be opened)
* Moving the language setting (consistent with APG)
* Graphical resources outsourcing (consistent with APG)
* Only one HTML template enabling JS use or not, and offering compatibility with mobile viewer
new features:
* Ability to reorder panoramas (affecting thumbnails and combobox)
* Panorama addition by double clicking in the main window
* Vertical move of the panorama with the mouse in hotspots editor
* Stylesheet editable via the Ctrl+U shortcut
Pro version:
* Tour on mobile is more complete (several 360° panoramas, hotspots ...)
* Ability to add custom context menu entries ( right click )
* Ability to reuse custom xml files ( export once, modify exported xml, say reuse external xml, export another time => it reincorporate external modification into the swf.
That's kprotect feature done with PanoTour ).
Bug fixed:
* 247: memory usage posted was not good
* 253: support for psd images
* 254: better behavior of the progress bar when opening a project
* 256: more robust refresh of the hotspots editor
* 261: export error when using a customized help screen
* 275: do not show hotspots during panoramas loading
* 283: some graphical objects could not be used as a hotspot (animation, video ...)
* 312: trapping memory error when creating panoramas and previews
* 319: more robust creation of the navigation bar with thumbnails
* 345: wrong size of the map at the beginning of the tour
Standard Version:
* 245: export without incorporating the images
* 297: no icon in Windows application
Pro version:
* 244: cube faces import was not reachable
* 263: image resolutions for mobile devices is set to fit at best hardware capabilities (IPhone/IPad)
Some reported crashes could not be reproduced. However, improving memory error trapping may solve most of them.
Resources policy:
Hierarchy: Kolor/ |- Templates |- Translation |- UI
Templates => Template used by PT for customizing outputs with xml script Translation => software translations UI => everything about software style ( icones, qss )
All theses files are initially protected in writing and updated each time. If you modify a file the writing protection is removed and this file will not be updated (keep your change). To disable your change simply remove the file and restart the application.
See this thread [[Link]] too about resources policy.
Exellent! Pass it over! (saw "Easy Rider" yesterday . .
PanoTour :
Windows 32 bits : http://ftp.autopano.net/releases/Panoto … -10-25.exe
Windows 64 bits : http://ftp.autopano.net/releases/Panoto … -10-25.exe
Mac Leopard 32/64 bits : http://ftp.autopano.net/releases/Panoto … -10-25.dmg
Linux 32 bits deb : http://ftp.autopano.net/releases/Panoto … -10-25.deb
Linux 32 bits tar.gz : http://ftp.autopano.net/releases/Panoto … -25.tar.gz
Linux 64 bits deb : http://ftp.autopano.net/releases/Panoto … -10-25.deb
Linux 64 bits tar.gz : http://ftp.autopano.net/releases/Panoto … -25.tar.gz
PanoTour Pro :
PanotorPro Beta2 is big progress.
I noticed that Littleplanet intro opens up after clicking on the 2nd hotspot. If I turn Thumbnaill "start open" does not fit the rails, even if I give a different size.
Tibor
Tibor
This is not the place to report bugs - see screenshot.
Sorry, I was wrong .... Firefox on the PC looks awful
Tibor
My attempt on the iPhone .... PnotourPro Beta 2
http://prohlidky.eri.cz/
Tibor
COMMUNITY Forums YouTube channel Google+ |
COMPANY Blog About Kolor Resellers Contact Visit us |
