#1 2009-05-06 08:37:37
Apapane
APG2-WinVista64-Quad core-8Gbytes RAM - Move Images Mode bug(s)?
I'm using APG2 to stitch gigapans I took of a recent exhibit of some of my etchings.  All 4 panos crash the GigaPan stitcher, even though I used a GigaPan beta with Canon S5IS to take the images.
Very strange occurrences when trying to use the Move Images Mode (when necessary).
This is after a succussful gigapan import and detection, working from the preview image.
1) I must switch windows and return to the preview before the image IDs appear after clicking on the Move Images icon and the Picture icon.
2) I can move images by drag and drop, but not by changing the values in the Yaw, Pitch, Roll, and FOV fields.
The top three images illustrate this.  First shows the Roll value before adjusting, second shows the Roll value after changing, but before making the change, i.e, before pressing Enter.  The third image shows the Roll value AFTER changing and hitting Enter.  It returns to the original value.  The same thing occurrs with the other values (Y,P, & FOV).
3) When changing magnification, I get two resolutions of the image, one of which becomes the background. see the 4th screen shot.
The full image is screen shot #5
Anyone else having this difficulty?
BTW, the other three walls worked just fine.  One can be seen at: http://share.gigapan.org/viewGigapan.php?id=22506
Suggestions/solutions are most welcome.smile
Mahalo,
Richard
Uploaded Images
#2 2009-05-13 11:28:55
Kolor CEO
Website
Re: APG2-WinVista64-Quad core-8Gbytes RAM - Move Images Mode bug(s)?
Confirmed. Editing the value doesn't work.
BTW: you can select an image ( with the numbered circle ) and then use arrow to slighty move the picture up/down/left/right. This works.
#3 2009-05-14 07:26:19
Apapane
Alexandre,
Mahalo for the confirmation about editing the values in the "Move Images Mode".  I HAVE been able to adjust Yaw and Pitch using the arrow keys or by click and drag, but still can't adjust Roll and FOV.  I look forward to a simple fix. smile
Richard
#4 2009-05-14 08:46:14
Website
Alexandre,
Richard
Although editing the numeric values does not work, I can adjust Yaw and Pitch and Roll (left/right arrows) and FOV (up/down arrows) using the arrow keys or click and drag with a six FE image set with APG V2 on a WinXP32 with GPU system - but click and drag to change FOV is sluggish and seems limited in range.
Could functionality or lack of it have something to do with how many images there are in the image set?
#5 2009-05-14 09:25:38
Kolor CEO
Website
BTW : We corrected this value editing issue too.
