#1 2013-01-30 16:31:42
Octavias
Website
Day & Night Transition in a Virtual tour.
Hello everyone!
So I want to start writing a new theme for my company that will include the day / night transition. I don't know much about XML but i have seen people incorporating them in their tours and they look AMAZING. I understand it would have to be some script that will change between two panoramas in a fade in/ fade out style.
Please help if anyone can help me with the code i would greatly appreciate it and i can compensate as well. I don't have a large budget, but i am sure we can work something out!
Thanks again,
- Octavias
"The whole point of taking pictures is so that you don’t have to explain things with words."
http://www.acmbphotography.com/ - website
https://www.facebook.com/ACMBPhotography - facebook
https://www.facebook.com/MaxBolotovPhotography
#2 2013-01-30 22:02:42
Website
Re: Day & Night Transition in a Virtual tour.
Hi Octavias
I will try to make up a template for you. Can you get your two panos with cube faces ready with your swf. It is better to use the krpano software to create your tour for this... I will send you the template where you just replace these files for yours to get it working..
#3 2013-01-31 00:05:00
Octavias
Website
Destiny to the rescue!
Thank for helping, Okay now you got to guide with what you need. I will shoot the two Panoramas ASAP for you but regarding exporting. What exactly do you need from me? I am using PTgui to Stich and PTP to export.
You can e-mail me if you like,
Thanks so much,
-Octavias
#4 2013-01-31 00:28:01
Website
Hi.. Well I am hoping you purchased PTP which means you can download and use krpano to create your tour.. You do not have to use it since ptp can do it too but with a lot more code editing, it makes it easier to replace the cube faces and swf using krpano.. The thing with this media, you cannot zoom in... its fixed as I understand it so save your pano to produce 1400 cube faces. You cannot physically see more than 96 dpi on any monitor so save and optimise at 80% 96 dpi.
http://krpano.com/download/
With the krpano all you need to do is drop your pano onto the droplet to produce the the tour.. You can then edit the nadir after. Droplets are amazing things. They are a kind of Macro recorded to carry out a process without having any prior knowledge of software or even having additional software..
This link will provide you with all you need.. Just download it and replace the swf and cube faces with yours, making sure you name your faces as they are which use cap letters.. You will need to add your krpano licences with the tour.
http://krpano.com/examples/blendcubes720/
I am sure you will work it out from this winter to summer where you can download the krpano example files.. but feel free to ask any questions.. I would keep the pano cubes small or it will take a long time to load.. 1400 is about the limit..
#5 2013-01-31 12:03:54
UK Pano
-Octavias
No don't email it as I'm interested in this as well!  Not from a Day/Night but looking at applying the same principle for a before/after
Thanks in advance Destiny smile
#6 2013-01-31 22:59:47
Website
Hi.. Ok, I will try to share and make sure its understandable and doable for all users.
To achieve this in the most simple way you need to create your tour and save-as krpano.swf
This code below is all krpano code but edited by me.
Later when you understand how it all works you can save-as any name but doing it this way all you need to do is replace the krpano.swf with yours and also replace the cube faces naming them as they are so their maintains correlation between the xml code. I have also provided a screen shot of the file structure. Simple and easy to understand.
I can send the files to anyone who asks for it, providing a zipped copy of this template setup.. If you need your tour to be in a table rather than as a full screen, I will send you a table structure. Also, if you need a menu set, you can just copy and past a set from any xml code but make sure you provide the full url and a folder with the menu graphics.
This is the test blend transition link..
http://members.westnet.com.au/dps/krpan … blend.html
This is the striped to barebones html source code..
<html>
<head>
    <title>Destiny krpano blend test setup</title>
</head>
<style>
body{ font-family:Arial, Helvetica, sans-serif; font-size:12px; color:#FFFFFF; background-color:#000000; margin:0; padding:0; }
* html, * html body{ overflow: hidden; }
a{ color:#FFFFFF; text-decoration:underline; }
a:hover{ color:#AAAAAA; text-decoration:underline; }
</style>
<body>
<div id="krpanoDIV"></div>
<script type="text/javascript" src="swfkrpano.js"></script>
<script type="text/javascript">
    var swf = createswf("krpano.swf","krpanoSWFObject","100%","100%");
    swf.addVariable("xml","krpano.xml");
    swf.embed("krpanoDIV");
</script>
</body>
</html>
This is xml code
<krpano onstart="start();">
    <view hlookat="180" vlookat="0" fovtype="HFOV" fov="100" fovmin="70" fovmax="120" />
    <action name="addface">
        addhotspot(%1);
        set(hotspot[%1].url, %2);
        set(hotspot[%1].ath, %3);
        set(hotspot[%1].atv, %4);
        set(hotspot[%1].width,  1000);
        set(hotspot[%1].height, 1000);
        set(hotspot[%1].distorted, true);
        set(hotspot[%1].enabled, false);
        set(hotspot[%1].visible, false);
        set(hotspot[%1].alpha, 0.0);
        set(hotspot[%1].details, 16);
        set(hotspot[%1].zorder, %1);
    </action>
    <action name="addcube">
        addface(face_%1_F, %1_f.jpg,    0,   0);
        addface(face_%1_L, %1_l.jpg,  -90,   0);
        addface(face_%1_R, %1_r.jpg,  +90,   0);
        addface(face_%1_B, %1_b.jpg, +180,   0);
        addface(face_%1_Z, %1_u.jpg,    0, -90);
        addface(face_%1_N, %1_d.jpg,    0, +90);
    </action>
    <action name="setalpha">
        set(%1.alpha, %2);
        if(%1.alpha == 0.0, set(%1.visible,false), set(%1.visible,true));
    </action>
    <action name="setcubealpha">
        setalpha(hotspot[face_%1_F], %2);
        setalpha(hotspot[face_%1_L], %2);
        setalpha(hotspot[face_%1_R], %2);
        setalpha(hotspot[face_%1_B], %2);
        setalpha(hotspot[face_%1_Z], %2);
        setalpha(hotspot[face_%1_N], %2);
    </action>
    <action name="start">
        addcube(blue);
        addcube(grey);
    </action>
    <action name="blendcubes720">
        set(overlap, 30);        <!-- set overlapping/blending range in degrees -->
        mul(edge1, overlap, 0.5);
        sub(edge2, 360, edge1);
        add(edge3, 360, edge1);
        sub(edge4, 720, edge1);
        mod(pan, view.hlookat, 720);
        if(pan LT 0, add(pan,pan,1440);mod(pan,pan,720); );
        if(pan GT edge2,
           if(pan LT edge3,
              sub(blend,pan,edge2);
              div(blend,blend,overlap);
              set(blend,1);
           if(pan GT edge4,
              sub(blend,pan,edge4);
              sub(blend,1,blend);
           if(pan LT edge1,
              add(blend,pan,edge1);
              sub(blend,1,blend);
              set(blend,0);
        sub(blend2, 1.0, blend);
        setcubealpha(blue, get(blend));
        setcubealpha(grey, get(blend2));
    </action>
    <events onviewchange="blendcubes720();" />
</krpano>
Uploaded Images
#7 2013-01-31 23:08:57
Website
I think you should point out that this doesn´t work on iDevices.
Here´s one with real images wink : http://360impressions.de/LTKuppelBlend/krpano.swf
#8 2013-02-01 10:41:25
UK Pano
Thank you Destiny for this and can see how the code works.  Simple when you think about it *blush*
Thanks also Klaus for the example with real imagery - very effective.
I have been renovating a house and wish to apply this as before/after transition.  I was originally looking to use a hotspot icon to trigger the switch, but his automated fade is much more impressive.
Thanks again smile
#9 2013-02-02 00:05:33
Octavias
Website
You guys are amazing!!! I had little time toc heck on the replies but wow am i happy i posted lol Thank you Destiny for the code, i will implemented it as soon as i can and wil get back to you guy with a result!
#10 2013-02-04 08:27:49
Octavias
Website
I did it guys!! it looks great, the only think i can't get to work is applying my license from PTP. Where would i find it? Is it a file? Because as far as i know i have my e-mail ad my registration KEY from the e-mail?
Please advice!
#11 2013-02-04 09:00:04
Website
When you create your own tour swf and and cube images, it generates the licences automatically... Just copy and past them to your transition tour template.... Since the licence was generated when you created you swf, it will work fine.. You are just replacing the krpano original file..
#12 2013-02-04 09:41:15
Website
Please advice!
You can export the embedded krpano licenses from PTP using the Help/Licenses option.
Uploaded Images
#13 2013-02-04 16:23:08
Octavias
Website
Awesome!
Thanks Destiny and Mediavets, i will try when i get home.
Also, i did it kind of a weird way for now, since i just started messing around with the code. I just took my test panorama and dropped it into the kpano droplet, it made the cubes for me and then i replaced it with the Blend Sample file i downloaded from your comments. I mean it worked and i had my two panoramas blend after a rotation but, i don't think its the most correct way, since i need my hotspots and all that to be embedded as well.
I will keep trying and re-reading this thread, will keep you guys informed.
Thanks again fro helping,
-Max
#14 2013-02-06 20:39:50
Octavias
Website
Hey gang!
So i got it to work with the sample theme! And ohh i am so excited about it!
The only problem is. when i exported the licences from PTP there was no 3rd licence (krpanobrandingfree.license) I cannot seem to be able to find this one, so the (kpano) is gone from my images BUT the "DEMO" in the middle still remains.
Please help!
-Max
#15 2013-02-06 20:49:00
Website
Can you provide a url to this..
#16 2013-02-06 20:51:09
Website
Do you have a branding-free license? This is not part of the PTP package but a separate product available at extra cost:
http://www.kolor.com/buy/software/brand … ano-1.html
Please help!
-Max
Not sure what you mean; but that's not related to a branding-free license, which remove references to krpano from the right-click context menu.
#17 2013-02-06 21:01:58
Octavias
Website
I am sticking another panorama and uploading it soon!
Destiny, i thought you said if i have PTP  license i can use k-pano to export it? Or should i just use k-pano to make my  cubes?
#18 2013-02-06 21:08:08
Website
You use PTP to export your cubic faces and create a tour to create your swf file..  Keep the size low or it will take a long time to load.. You then rename your cube faces as my demo I provided and replace the cube faces and swf for your own... Once you understand how it all works, you can change the names in the code to your own.. This is the easiest way to get it to work... You can use krpano to do all this too, but what I am saying with krpano, since you own ptp, you can use the krpano download as your template.. PTP will generate your licences for you...
#19 2013-02-06 22:32:33
Octavias
Website
It worked! Destiny you are amazing! Thank you so much for your help!
This is what i have so far. There is a square of some sort that pops up when the blend happens, any ideas why? also how do i get my navigation menu in there?
http://www.acmbphotography.com/Day%20an … blend.html
Thanks in advance!
- Max
#20 2013-02-06 23:10:35
Website
It's a nice feature.. I sure hope its in the new PTP but with a loader... or others might think its not loading.. I can see it having many uses.. You need to fix up your cube faces and also optimise more.. Remember, no monitor can see more than 96 dpi so if you set your faces at jpg, 80% at 96 dpi with max faces about 1400 X 1400 it should work fine..
Well done..
#21 2013-02-07 16:41:07
Octavias
Website
It really is a nice feature. I am gonna optimize the cubes when i have some free time again and show you my results!
-Max
#22 2013-02-07 19:17:40
Website
Sorry, Destiny: you´re wrong.
My Apple 30" 2560x1600 px has 100dpi.
Apple´s 15" MacBook Pro Retina (2880 x 1800) has around 220ppi.
NEC MD205MG-1 2560x2048 @ 20.1 has 163dpi
There´s a growing number of displays which definitely exceeds 96dpi/ppi.
#23 2013-02-07 19:24:49
Octavias
Website
Klausesser, If that is so, Why is my cube images have that weird square on it? Do you have any idea? And how do I obtain my navigation bar in the tour, is that possible?
-Max
#24 2013-02-07 19:58:30
Website
??? Sorry?
#25 2013-02-07 21:24:53
Octavias
Website
Thanks in advance!
- Max
That's the link to my panorama, would you kindly take a look please? Do you have any idea why that weird square shows up when the transition happens?
Everyone's help is highly appreciated!
