#1 2012-07-16 14:55:24
marco-pano
Website
[APG 3.0.0 A1 - Win 7-SP1 x64] Minor bugs
Trying this APG 3.0 Alpha1, I'd like to say first that I'm quite impressed by the work done and the speed under Win7 x64.
I noticed some minor problems:
1 - in my global setting, detection Tab // Automate options, "Auto color correction" and "Auto color histogram" are selected. These settings are properly transfered to new group detection. But after detection, the panorama colors don't seem correct (picture 1) and the histogram seems very "flat" (picture 2). I must click on "Auto" button to get a better picture (picture 3 and 4).
2 - In the rendering file template, the "%f" shortcut to get the panorama extent in Theta and Phi is no more working, I just see %f in the ouput filename.
But this is still an Alpha 1 :wink
Bon courage à la Dev's team.
Uploaded Images
Marco, Paris wink
#2 2012-07-17 10:30:59
renan
Re: [APG 3.0.0 A1 - Win 7-SP1 x64] Minor bugs
issues 1427 and 1428 open.
#3 2012-08-30 13:54:51
ThomasV
The issue concerning the %f is fixed in Autopano 3.0 A2.
Concerning the 'auto color histogram', the issue has been found and will be fixed in the coming beta version.
Thanks for this valuable feedback,
Thomas
#4 2012-09-08 11:39:30
marco-pano
Website
ThomasV wrote:
Thomas
Hi Thomas,
'Auto color histogram' is not fixed in v3.0 A3.
As far I can understand, main problem comes from that the default setting fix the Black or White clipping to 10%, which is too much, really too much yikes
If I change settings to 0.0% or 0.1%, result is nice wink
All the best.
Marco, Paris wink
#5 2012-09-08 15:16:36
Website
wink thats why Thomas wrote "will be fixed in the coming beta version"
#6 2012-09-09 10:54:23
marco-pano
Website
Hi Georg,
Wait and see the next Beta wink
I was just giving my understanding for users wanting to apply level histogram and not happy with the result in v3.0 Alpha X.
Marco, Paris wink
#7 2012-09-10 13:32:07
Kolor CEO
Website
First beta is planned this week just before Photokina. It has some great fixed like GPU support.
#8 2012-09-10 14:31:01
ThomasV
Hi Marco,
Just one question: Did you uninstall the previous alpha1 or alpha2 versions before installing alpha 3 ?
Since the preferences are stored in the windows registry, the wrong values (10%) are saved here. Therefore, if you didn't uninstall, those wrong values are used for the alpha 3 version too.
The fix is in the alpha3 version, so if you could double check it, it will be nice.
Thanks,
Thomas
#9 2012-09-10 15:09:28
Website
ThomasV wrote:
Hi Marco,
Thanks,
Thomas
so in case I did not uninstall A1 and A2, but only did install A3 (and overwrite A2) whats to do to get the 10% corrected?
#10 2012-09-10 15:45:15
ThomasV
Hi Georg,
In this case, you can uninstall A3, and re-install it. Uninstalling A3 will remove the settings stored in the registry, and then default values will be corrected at reinstall.
I understand it can be tedious, and apologize for that.
Regards,
Thomas
#11 2012-09-12 07:32:48
marco-pano
Website
ThomasV wrote:
Hi Marco,
Thanks,
Thomas
Thanks Thomas for this information,
I confirm that I didn't uninstall alpha 2 and overwrote it by alpha 3.
--- updated
I now uninstall alpha 3 and install again from scratch, default settings for black and white clipping is now 0.10%, much better.
Thanks.
Marco, Paris wink
